I've posted the following poorly worded and poorly constructed thought elsewhere:
I've mentioned a few times that an Internal Reflection Optical Device might be designed with multiple inputs.
In the hole of a common IROD is a refraction lens that directs the rays to the correct angles to reflect off of the side walls of the main optic forward. Of course, this is taking advantage of
indices.
I think the challenge in designing a multiple input optic would be to alter the multiple refraction optical lenses to correctly direct the rays. If this were successfully designed I believe the rays from each of the emmiters would be adequately mixed and result in a beam void of fringe colors.
Take it a step further. Have all the emitters seperately driven so their output can be adjusted to get the color mix you want.
Take it a step further. Design the optic so that the output side was not flat but coned with a tiny dome shape or side emitter shape on top. A de-collimating design element if you will. Insert the tip of this whole rig into a parabolic reflector for a single, almost point source.
Now you have the light from 3 or 4 LEDs being emitted from one source directed forward by the reflector.
I think it's a viable idea. It needs a needs a couple of PHDs in optics and a couple of optical prototypers along with a large bag of money to come to fruition.
