bigchelis
What's the size of the reflector, and is it removable?
+1
What is the size of the reflector. It looks about the size of a P60 drop-in.
What about a beamshoot of the reflector itself. Please.:wave:
Reflector diameter is about 25mm with LOP texture and of course removeable.What's the size of the reflector, and is it removable?
Will fit and focus perfectly if you have or can obtain one. :thumbsup: :thumbsup: :thumbsup:FM 1794 won't focus in this either?
FM,
I received mine today and noticed that there is some assembly required regarding the Carly lamp. The stems are very long and when installed hit the inside glass of the turbo head. Any suggestions as to exactly how long to cut these or is it just trial and error?
thanks,
All CL1499 bulbs come with uncut legs or pins. You need to cut and shorten the pins to length of about 4.5mm from buttom of bulb glass.
Make sure to trim end of bulb pins.
Is there an available 3.7V bulb that will focus in this, to use it with a single cell body (E1, FM 1x 16340/1x 18500, etc.)?
Like a Strion bulb, but longer (to focus in this).I am not saying it's not existed but I never seen this size 3.7 volt bulb.
Nice setup donn! But are you sure the 1794 can handle 2xIMR 18650s? I asked FM about running the 1794 on 2xIMR18500, and he said that they would will most likely kill the 1794 or at least push it extremely hard. Since you have the soft start, that removes some of the risk though..I'm running a 1794 on 2x IMR 18650s.
