flashfiend
Would you consider bringing back this design for your turbo heads (I'm interested in the one on the left)?
As well as perhaps some more E-series compatible parts; a mini-"turbohead" would be nice and could be lighter, sleeker, and better looking than fitting on an adapter and a C-series head.
They already existed and available.
Body extension to allow use of four 26650 cells in the 5 x 4&5 IMR26500 M*g by FiveMega
You can run 4x 26650 cells in the 5x 26500 tube. Pull out the stock spring and replace it with a much shorter one.
My 26500s LOA is 1.969" My 26650s LOA is 2.618"Body extension to allow use of four 26650 cells in the 5 x 4&5 IMR26500 M*g by FiveMega
There's another thread here lamenting the lack of interest in MiniMags. A good mod like this might being a few back. Personally I'd love to annoy friends with 6D mags with a hotwire MiniMag
But now that AW is promising us an IMR 14500 very soon:I had a plan of making ROP low bulb conversion for Mini M*g but there is not enough interest.
The mighty ROP-High (3853-H if not the 3854-H?) should now be theoretically possible in a 2xAA Minimag?Got a PM from AW saying that he will be releasing a 14500 IMR in a few weeks. It's rated for 8C (5A).
What Incandescent flashlight(s) can be made but nobody make them.
CPF should make an "open source" flashlight.
Design & spec 3 interfaces. The head/bezel, a swtich or adapter housing, and a body.
Then publish the design drawings so anyone can make the pieces. They would all be interchangeable.
We could have so many options then.
Hey fivemega,
I have noticed that the FM1909 bulb is no longer available. Any chance of another run becoming available in the future?
How about another run of Strion sockets when the Onion Ring comes out? :shakehead
Quoted for truth. This would be awesome.
Also, what about a regulated battery holder for the Princeton Tec Torrent?
I'm not up on this bit of news either, but I wonderlite who might be able to have more made? :devil:Where'd you see that? That would be awful, I didn't think to order a single spare even, not so soon.
If memory serves me correctly, the "Onion Ring" is, or was, a Surefire Aviator 2 project, by CPF member Koala, to replace/improve the ring of 5mm LED's around the incan bulb. I don't believe it ever came to fruition. Whether or not FM's Strion E-socket was meant to also fit the A2, I can't recall offhand.You mean D26 1.5mm sockets he already makes or the E2E Strion sockets he also has available?
... what's the onion ring...?
3x18650 Megalennium is closest possible flashlight body.An Incan which is around 700 / 800 lumens, SF M6 size/style, 2 hour run time, can run on a variety of batts eg. primaries / rechargeable etc, beam which is half throw / half spill - possibly adjustable....
How about a 2.5"D" ROP M*g? (7.4V, 5200mAh)Anything long running in a FM body would be useful. How about something with two hours runtime? Three hours?
Any body else interested on these?Body extension to allow use of four 26650 cells in the 5 x 4&5 IMR26500 M*g by FiveMega
Some PVC tube will work for 2x18500 cells in 2C body.Retrofit kit to convert Prince series to handle 18500, or 18650.
Some type of extension between the body and head would work.
Wouldn't 3x18650 be too long?Also an extension to convert FM85 3c to 3 18650.
Megalennium shaped flashlight body involved with lot of machine work and cost is too high for a flashlight body (without head) which runs few minutes per charge.How about the Mini-Megalennium? A Megalennium shrunk down to hold 3AA sized cells with a D36 sized head (or something else to get the correct proportions).
3xIMR 14500s + 1185 might interest some people, or one could use 3X Nimh or 3X LiIons with a LED head.
I will do another run of various size extension.More 37mm extension tubes to enable the MagCharger to run Welch Allyn 1111 and 1274 bulbs now that the 1160 is extinct.
Another run of FM1909 bulb is in process and available to purchase here.I have noticed that the FM1909 bulb is no longer available. Any chance of another run becoming available in the future?
I doubt if there are more than 3 people interested for such a product.what about a regulated battery holder for the Princeton Tec Torrent?
