LA OZ
So that I can purchase two for myself .
If you want one, voice your request here.
Personally, I dont think Fenix will produce a headlamp in the near future. It's a completely different thing compared to a normal 'round' flashlight, also a headlight typically isnt made out of aluminium, what Fenix now uses for all of their lights.carrot said:I'd love to see one running off the user's choice of 1AA or 1x123, with some kind of piston or spring that accommodates both. For the 1AA, it would be bored so that neither AA's nor 123's will rattle inside the body.
+1... i had a similar idea with a 1x123 surefire tube horizontal with a normal surefire bezel... suprisingly the weight is pretty light... the light just need to make sure it doesn't get too hot thoughchevrofreak said:I think it would be cool if Fenix or an aftermarket company came up with an aluminum headlamp body for the P1D head that holds the batteries horizontal and has a reverse clickie switch to make mode changes easier. 2xAA or 1xCR123 shouldnt be too hard to do
4sevens said:I'm sourcing a 1xcr123a cree XR-E headlamp right now.
80 lumens (2 hours) on high
15 hours on low
It's NOT fenix though
YES.beautifully-stupid said:ahhh... Ideally ... 2 cree's
Off the deep end
- 1 narrow focus for throw
- 1 wide focus for task
- the ability to use them at the same time.
- Same look and feel as the stenlight.
- incorporate batteries into housing or provide plug in for optional pocket carry.battery back
- you could even... hinge the light housing to the battery housing so the light can unfolded flat for pocket carry.
- ohhh and it needs to be around $49
More info, please, 4sevens!4sevens said:I'm sourcing a 1xcr123a cree XR-E headlamp right now.
15 hours on low
