markr6
- Joined
- Jul 16, 2012
- Messages
- 9,258
Both of those 219B beams look great. I think I prefer the d-c-fix since it leaves a little bit of a defined hotspot. How far away are you standing, about 8 feet?
I love how smooth the floody optic looks, but I'm also leaning towards the d-c fix just because having a bit more throw... and it gives the option of removing it
I like the floody optic,
but for a defined Hotspot application,
could you also please share a pic of the beam with just the clear lens, No-DC, No-Floody optic
Thanks, looking forward to see this as well.Certainly, I'll do that later tonight.
Looks like a nice trade off in lumens. You get better throw and way nicer tint and CRI in return. Thanks for sharing.Clear glass as promised. I measured 5135 cd or about 143.3m turn-on throw at 505 lumens. The stock SC64c is about 128m at 770 lumens.
505 lumens with clear glass,
465 lumens with d-c fix
440 lumens with the 15 degree frosted optic
thank you for sharing your work, those little SW45 Zebras are Fantastic! I say "little" because they are actually smaller, lighter, Brighter, and considerably less expensive, than an HDS...
Hey McBob,
Is the frosted glass the same as offered by ZebraLight, or is it a different kind? If the latter, can you provide a link?
I have an H53Fc and H53c + DC-Fix and my observations are similar (but with no numerical data). Very pleased with how efficient DC-Fix really is and highly recommend. I still prefer the frosted optics for headlamp use.
XPG 3700k w/DB on the left 219C 3500k on right
For the d-c fix I was particularly pleased to see it makes very little difference to the tint. Maukka kindly did an informal test for me to check this.
Zebralight just added the SC64c LE to the spreadsheet, 4000K LH351D. I guess I should be flattered I hope they increase the top end a bit because the Samsung can easily handle 1000 lumens, but either way this will be a great light.
thanks, I have seen the pictures above, and is the 4k yellow much?
It's quite yellow compared to 219B sw45k or E21A sm403, but about the same as something like a 219C.
