Re: A Little Accident. Enjoy.
[ QUOTE ]
StuU said:
Surefire lithium-powered flashlights are marketed and used intensely in many different places and for many different purposes. And I can't remember every hearing about any lithium Surefire light exploding even with all the countless hours that these lights are used around the world.
[/ QUOTE ]
Of course, there is not a place for a person to get this information, so the lack of hearing is quite probably a lack of communication.
This is not the first SureFire related detonation/fire/explosion of a 123 cell.
If you dig, there is a story around here about a Nuclear plant that issued SureFire lights. After the wall locker burned, they pulled all SureFire lights from use. And this is not the only case....
I think this was it:
SureFire G2 123 cell fires and more
It takes quite a bit of digging to find other reports, but here is another example:
The Flight Attendant had purchased the flashlight from a
store in Beijing. While the flashlight was turned on, the
passenger accidentally dropped the flashlight. A few
minutes later, while the flashlight was stored in a seat
pocket, the flashlight began emitting smoke and noxious
fumes. The flashlight became hot enough that it could
only be handled with oven mitts.
The airline reports that this is the second time a LED
flashlight, purchased in Beijing, has failed in this
manner. The first time it occurred, the flashlight was
being used at the home of an employee.
HAZARD
Consequently, as a safety precaution, we recommend
that flashlights with LED lights and 3 volt lithium
batteries not be transported in aircraft carry-on or
checked baggage.
http://www.haffa.com.hk/files/DG%20LED%20Flashlight%20Warning.pdf
More stuff:
http://www.interfire.org/features/recallview.asp?date=02092004
http://www.batteriesdigest.com/safety.htm
http://www.newsnet5.com/consumeralert/2510994/detail.html
The end of this page from the Pelican website:
"An additional safety related attribute of Pelican flashlights is the built in patented hydrogen purge valve that allows explosive gases to harmlessly leave the battery
compartments. In addition to this patented safety feature, pellets have been encapsulated into every Pelican flashlight. These tiny catalyst pellets combine outgasing hydrogen discharging from batteries with ambient air trapped inside all flashlights, changing the mixture to harmless water droplets. This serves as an additional “backup” fail-safe not found in other lights. Battery powered flashlights are potentially dangerous due to the hydrogen gas given off by over heated battery cells exploding as the unit is turned on.
This has resulted in occasions where the flashlight can explode, causing bodily harm. To combat this potentially dangerous situation, Pelican flashlights now incorporate a special one-way valve that allows small amounts of hydrogen gas to harmlessly escape, yet prevents the ingress of ambient explosive gases.
All federal and nationally accredited approval agencies now recognize this potential hazard and have set specific test procedures to ensure that these flashlights are not susceptible to self igniting explosions. Many popular competitive brands have still not incorporated these safety features into their products."
http://www.pelican-cases-flashlights.com/flashlights-chart-selector.htm
