MAD777
vinhnguyen54;5257127 I think Triples will throw even more than Quads but of course Quads has a bit more lumen.[/QUOTE said:Why would triples out throw quads?
This is all speculation from me since I'm newish, but given the geometrical restraints of head size (equal/constant) and shape (circular), if you cram 4 LEDs into the same size head as 3, you require smaller reflectors, and there is more empty space in the center of 4 circles than 3 circles which fit more snugly together with less center space wasted. Thus, 3 should provide a tighter hotspot.
I could be way off.
Brandon
D4vn + +W1 + VTC5A = 2500 Lumen and 62Kcd (EXCESSIVE HEAT NOT RECOMMENDED)
Vinh, would you say the W1 in the EC65vn will have the same performance since they use the same carclo optic but with less heat due to larger size?
I'm anxious to compare EC65vn with D4Svn with white flats!
