Re: First Impressions of HDS U60 & Quirks/Qs/Comme
[ QUOTE ]
joema said:
[ QUOTE ]
aceo07 said:
...I saw a camping thread in the general flashlight forum and thought about the HDS EDC...I think it need to be longer...for more substance to hold onto and not drop. It'd probably be tethered to me...
[/ QUOTE ]
I think the HDS EDC is a superb camping light -- variable output, yet 60L and good throw when you need it.
Depends on the type of camping/hiking, but variable output is really nice. These new high tech lithium/LED or xenon lights put out too much light for many nighttime camping scenarios. You want that output available, but not all the time. The lower output also gives much longer running time. The HDS is perfect in that regard.
As you said I think tethering may solve the dropping problem.
Also the HDS clip orientation allows attaching the light to a cap for a headlamp, often useful during camping.
[/ QUOTE ]
I totally agree that it'd be great for camping.
As for hiking, I feel the HDS is a little short for a fully secure hold. The HDS is the length from my pinky to my index finger. Maybe a tiny bit longer so it still has some room to slide in my hand. A perfect grip on the HDS is always at the same position, completely in my palm, else doesn't feel as secure. With a longer flashlight, I could grip it at a slightly different position and still maintain good hold on it. Hiking at night requires that I pay attention to everything around me and keep moving before it gets much later. Not having to think about how I'm holding my flashlight or thinking that it might slide out of my hand is one less worry for me.
Camping is a little bit different. The surroundings are familar and not as dangerous. If it drops, it drops on flat ground and my attempt to recover it will be safe. It would be tethered during hikes, but if it drops it might distract me from other things.
It might not be as bad as I think. I have yet to take my 1 week old U60 hiking. I hope to not have to use it during a hike. It's generally not a good sign when you need to use a flashlight to complete a hike. It means you didn't start early enough or you didn't go fast enough or it's a really really long hike.
