I use Kinoko and ET 14500s in my D25A and D3A w/o any fit issues.
That's good info to know. EDIT: It's good that ET has (apparently) corrected the issue w/ length for their 14500 cells re: D-series 'A' lights
. I like options.
For the benefit of any reader needing cells for those lights, I should go ahead and post my choices for 14500s for these lights, which I found after realizing that the ET cells of that time were
far too long for the application (and still sit NIB, unused to this day).
These are my daily drivers in these lights:
Nitecore NL147R 14500 Li-ion BatteryNow with a Built-in Micro USB Charging PortThe Nitecore NL147R 14500 Li-ion Battery now features a built-in Micro-USB charging port. The charging port on the side of the battery allows the user to charge the battery dir
www.batteryjunction.com
At 49.5 mm, they're the shortest prot. 14500s I know of, and are therefore optimal for these 'A' lights. Amazingly, they also have direct micro-USB charging as well! While that was not a decision factor, I like having a few such cells of each size I use most, because they're handy when traveling, which is just an added bonus. I'm sure you might appreciate that as well. They tested well when new.
At 50.5 mm, these are my second choice. While a bit longer, they're still acceptable to use, and I am therefore using these as well. They don't 'feel' as good when I use them, so they're second choice. They also tested well when new:
Built-in PCB keeps your battery from over-(dis)charging and short-circuiting, protecting you and your devices from accidental harm.Li-ion chemistry is friendly to your wallet and the environment, letting you recharge the same cell over and over.1.6A discharge can easily handle the needs of many...
At 51.1 mm, the cells currently listed on the IG site are
likely OK, but I still prefer the shortest good cells I can get in these lights. It's good to know about them for another option, and they have a good current rating for more 'headroom' as well:
2021 Version EagTac 14500 3.6-4.2v Rechargeable Li-ion Cell (AA Size) 750mAh IC PROTECTED Rechargeable Cell ( 4.2V hot off charger) Features: - Measures only 51.1mm in height (+/-0.1mm) and 14.4mm in width - IC protected for a) over-charge, b) over-discharge, c) short circuit, d) current...
illuminationgear.com
I definitely don't like to over-compress compression springs in flashlights, as that can cause issues, and all else equal, shorter is better. Given that I used shorter, unprotected cells for a good while until I found the above, I know what these lights
should feel like with a proper length cell, and if the spring is nearing over-compression before the head bottoms out, I can feel that, and it's something which is something I want to avoid.
