Well, I recently got my L0D Q4 and like it, but I compared it to a regular L0D-CE and have to say there is a very small difference if any!
The light colour is much whiter or "bluer" if you want, so it may look a little brighter but I tested the two lights outside and there really was no big difference.
Also the colour of my L0D Q4 is more orange than red. Well, better then pink...
At least I like the christmas logo a lot since I'm a huge Christmas-fan!
P.S.:
I would really prefere a higher PWM frequency over a few percent more light!
The original L0D-CE was spec'ed at only 50 Lumens where the new L0D-Q4 is spec'ed at 75 Lumens.
This is enough of a difference to definitely be noticeable but it takes something like a 2 to 1 difference before it will really start to look dramatic.
Also the Lumens spec may have been a little on the conservative side on your original L0D-CE as later P4's improved in output, and tended to fall near the top of their bin.
In any case this is one bright little light!
I agree 100% on the PWM frequency. My C-LE uses about 3 times higher frequency, and that does make a difference.
With the L0D I rarely notice the PWM, but with the C-LE I NEVER notice it.
In Europe standard fluorescent lights flicker at about 100Hz just like the L0D (they turn on and off twice in each full 50Hz AC cycle, once on the positive swing and once on the negative swing), but in the U.S.A. this would be 120Hz, which is a just bit higher than the frequency the Fenix L0D-Q4 uses for PWM so I think we are a little less able to tune it out.
I think Fenix felt that they were on solid ground because the 100 Hz they used is higher than even ergonomic computer monitors (that only have to refresh at 75 Hz or higher), but the light output created by the PWM is choppier than a monitor, so you need a higher frequency like 300 to 1000 Hz to make the PWM really unnoticeable.
At first I thought that this would only involve a software change in the lights processor, so was a little miffed that Fenix hasn't made the change to a higher PWM frequency yet.
Now, as an engineer I think that I can see at least one reason that Fenix may be holding off.
I think you can probably blame the 10440 crowd for this situation. You see the L0D was never designed for these cells, but does work after a fashion. Fenix is well aware that this is going on, and may be concerned that the change to a higher PWM frequency would result in much more stress on the PWM chopper MosFet when 10440's are used.
They may have done some testing on this and decided to leave things as they are to avoid problems, with higher failures in the PWM circuit.
The old V1.0 C-LE used a lower PWM frequency which was even more annoying than the L0D, but with the V1.2 and V2.0 versions, now the frequency is much higher, and I find that it is almost completly unnoticeable, but the V1.0 C-LE would work with 10440 cells and the V1.2 and V2.0 will NOT.
Even the slight increase to 300 Hz like the C-LE uses would be a big improvement, and there are small SMT MosFET's available now which should be able to handle this higher frequency even with the higher current of a 10440.
In any case, even if they have to do a little re-engineering on the driver, I hope that Fenix will figure out some way to bump up the PWM frequency by at least a factor of two or three, because this low frequency PWM issue keeps some folks from even considering the L0D, and they are loosing sales as a result of this.
