I heard lumapower MRV is not that bright though? How is that compare to pelican 7060, tiablo a8 or a9, gladius or a striker VG?
I have none of those flashlights, but i can compare them to my issue poly stinger as well as my new inova t3.
The MRV out throws both flashlights by a good margin. It has better spill than the poly stinger. Kind of matches the spill of the T3.
The thing is that it has a tight focused beam and some throw. The throw is enough to iluminate a medium sized room pretty well. At close range the bright spot is relatively small, but that means that at distance it has a good sized spot light. At 6 feet the bright spot might only be a few inches wide. but even then the spill is still better than the stinger.
While in waikiki i was pointing it up to 15th or 20th story balcony and it would iluminate the place fairly well.
The beamshots on the lumapower website are fairly accurate.
http://lumapower.com/products/mrv/bsMRV.html
Basically put this flashlight moves LED lights into competition as long range lights.
As far as build i havent found anything wrong with it yet.
I suspect it would have better throw than the pelican though.
