the_guy_with_no_name
- Joined
- Dec 11, 2009
- Messages
- 3,939
Nice, I've waiting forever for aaa battery holder. The 10440 holder will fit one aaa battery right?
Hi Newguy2012,
Thanks. Yes a AAA battery will fit as well
Tgwnn
These look excellent, Guy!
I see the titanium 10440 body but not the copper yet - As you state it will be available soon?
it works for the Titanium but not the copper (the message says "unavailable" when I select this); I wanted one of each with the 10440 body.
Thank you
You'll like the HF-R! It's quite different.I just ordered my first HF-R from Illumn.com, along with a pair of 10440s and the Nuke charger. It should be better than the jury rigged setup I've got going.
I'm pretty excited. The Torpedo was my first and only MBI piece, and I wanted something to go with it.
There should be an o-ring between the lens and the bezel ring. It is possible that it got pinched or the bezel ring may not be tight enough to make a seal. Send Guy an email mbimbi777 @ gmail.com, He will get a reply to Your trouble sooner.I tried to send Guy a PM about this, but his inbox is full it seems...
I just got the HF-R Ti, and charged a couple of Nukes to use it a bit. I used it in the rain earlier when putting stuff in the car, and noticed now that there are a couple of drops of water inside the lens. I didn't figure the lens didn't have an o-ring around it, and now I don't know what to do.
Anyone have a suggestion?
My only other point of concern is what happens sometimes on high. I've got the Nichia 219, and sometimes on high, the tint immediately shifts to a weird blue. Gut reaction is overheating, but it doesn't happen after use, it happens after the light has been sitting there at room temp for a while and feels cool to the touch. Low and medium are fine, then as soon as I go to high, a half second passes and the beam turns blue.
Does anyone else have this, or did I just hit the lottery with a troublesome light?
Your description sounds like the encapsulate over the LED has been compromised allowing air, or in your description water, to get to the LED. Like NewGuy asked, can You post a picture of the LED with the reflector removed? A tint shift is very likely if one is not careful with over-driven LED's. Compound this with the HF's small size, heat can build up quickly allowing for an accelerated tint shift. One more, if water was present when the light was on high, it can heat the water droplets hot enough to cause them to steam, which can accelerate the LEDs encapsulant to become compromised, or in the case of a modder, a de-domed LED.My only other point of concern is what happens sometimes on high. I've got the Nichia 219, and sometimes on high, the tint immediately shifts to a weird blue. Gut reaction is overheating, but it doesn't happen after use, it happens after the light has been sitting there at room temp for a while and feels cool to the touch. Low and medium are fine, then as soon as I go to high, a half second passes and the beam turns blue.
I would leave the bezel off and pull the battery and end cap and let it bake in the hot sun.Thank you Mr. Lumens, much appreciated. I actually got the bezel ring off and blew out the cavity and reflector. It's set up with a light warm air going over it to totally dry it out, and I'll pop it back together in a little bit. Seems fine, still functions normally.
I'll still drop him an email on advice about tightening the bezel without a tool.
