Back to the topic.....it should be here any hour. I will most definitely report back.
Welp, I've had enough time with the light for a micro review.
For those that don't like to read....In short, this is my new do everything light. I value durability, reliability, water resistance, runtime & US manufacturing. The MDC TAC HA ( Hi-Med-Lo ) scratches that itch and then some. If you value these attributes,
buy one, then buy another and then grab one more. Review Over.
Form Factor:
Out of every light I have had this is now my favorite. It is small and lightweight with just enough heft to know it can take a beating or dish one out. This is very much a Malkoff. The fit and finish is great. The machining is excellent and there is something that feels high end, almost luxurious when screwing in the bezel ring. The tolerances are nice and tight and there is not a loose thread to be found anywhere on the entire light, ROCK SOLID. That said, if you have an interest in removing the bezel for any reason I highly recommend spending the $20 bucks to pick up the MDC bezel tool. Well worth it and it functions perfectly without scratching up your light trying to get the bezel out. I also run the light clipless as I like that it rides at the bottom of my pocket on my strong side with my Spyderco Domino comfortably clipped above it with the compact size of the MDC preventing them from clanking together. The included clip protrudes past the tailcap for deep carry and it does tailstand although at an angle. At first I thought a better tailstanding clip may be good, but the longer it rides at the bottom of my pocket unnoticeably, the more I like running clipless. If you absolutely have to have a flat clip there are options out there with some searching.
The UI:
I admire Gene for rolling the dice and coming up with what I consider a very unique and extremely useful UI design. No risk, no gain right? He gambled, he won.
Well done. The breakdown: If you leave the light ON longer than 7/10 of a second, the next time you turn it ON it will start in HIGH.
If you press the switch and it's less than 7/10 of a second the light will cycle to the next mode. There is no time limit for the light to be OFF to cycle to the next mode. This is especially handy if you require the next time your light comes on to be @ 3 lumens. You simply quick press to medium and the next time you go to turn it ON, it will advance 1 mode and turn ON in LOW. Now, this
almost seems to not make sense ( this is where I should have paid attention in reading comprehension rather than throwing pencils in the ceiling. ) as it's stated on the website "the light will always start in high". This is true…The default is HIGH in the normal course of use. You turn the light on and use it for a few seconds or longer than 7/10's and the next time you turn it on, it will be HIGH. So in a scenario of lets say, an LEO, when you use your light it's very likely longer than 7/10 of a second. You then turn the light off, but when you need it again and turn it on, it will come on in high. In short, it took me a little time to get used to, but now that I have, I find it to be a brilliant & simple design and like it quite a bit. It's completely second nature now, and I am able to operate the light instantly with muscle memory. For those that require a true single mode tactical light there is also the MDC SHO available, 50-60 minutes of a FULL 250 lumens. I will hopefully be getting one of these as well if I can.
Runtime:
Excellent. High is 50-60 minutes of a solid 250 lumens with a looong taper. Medium seems accurate at 25 lumens for 20 hours and even though I haven't had the opportunity, I have no doubt about low @ 3 lumens for 100 Hrs. This light is an absolute vampire. My guess, exceeding those regulated runtimes your likely to still have
quite a bit of light. I ran the cell on high and got around 6 hrs of lumen to sub-lumen output after the initial 1 HR of regulation. Let the cell rest even after it goes out and I have no idea how much more you can get out of it. Lets just say the total runtime exceeded my patience of trying to determine what it might be. Apocalypse approved.
Very Nice.
Waterproofyness:
The MDC is sealed for weather. In my testing, you are just fine in any type of weather. Beyond that I have subjected it to a few dunks with no ill effect's. One thing to mention, if you remove the bezel ring to swap bezels or simply out of curiosity, be sure you put the o'ring in after the lens. When tightened, the back of the bezel is designed to spread the o'ring against the lens and the sides of the head to form a seal. At a later date, I may or may not provide more testing data in regards to submersion, but for now, Im content with weatherproof & very water resistant. It performs as advertised - no prob Bob.
In closing:
This is now my do all light. It rides with me wherever I go and also serves 6 or so Hrs of 25 lumen candle mode per night. I have nothing to offer in criticism in regards to the MDC. I do however have something positive.
The MDC TAC HA is another EXCEPTIONAL offering from Malkoff.
HIGHLY recommended, VERY well done.
110% Forrest Approved.
:thumbsup:
