- Joined
- Jan 26, 2015
- Messages
- 2,123
Sounds like a neutral tint MDC with a TIR lens for max throw.
Sorry, can someone help me with what MDCn HOT means?
TIR? I'm 99% sure gene will stick with acrylic because it doesn't shatter. After all, why have a fully potted head if the lens just shatters! LOL! I also apologize if TIR is acyrlic...
I was hoping for a neutral version of this head.
http://www.malkoffdevices.com/products/e1t-scout-m300-1cr123-head
Dual mode MDCn HOT soon!
Can someone fill me in on what a MDCn is? Does the n stand for neutral?
Yes. The N stands for neutral. Usually around 4000K.
I thought you bought a cool 400 lumen Li-Ion XP-G2 head.
Soon!
Whole idea I'm throwing around is a tac light that I can detach and use and also uses a type of battery that you can find anywhere. There's almost no AA single output tactical lights really. The idea of using the E2 body is good since it has a proud button. Also I use a single point sling and have the front sling swivel removed.I read here that the outer diameter is the same for CR123 and AA bodies, so the diameter of the AA body is .800 inch. The tail section measure .900 inch so it will probably be able to be inserted into the mount, as long as the clip is removed. Aimpoint M4s use AA cells, so it seems that lithium primaries should be an acceptable (though not ideal) power source for the AR platform.
The CR123 SHO head will work fine with two AA lithium or alkaline batteries. It will NOT work with any number of Li-Ion 14500 batteries. The maximum allowed voltage is specified on the product page as 3.3 volts.
Does your AR have a sling loop at the rear of the FSB? If so, activating the shrouded tailcap of the MDC body may be problematic.
Surefire E2D, E, L, etc bodies are easy to find and work well with the Malkoff E2/Scout head, which has a voltage range of 3.4 to 9 volts, and runs in direct drive below 3.4 volts. As shown in an Elzetta video, a light with an exposed switch can be activated by pressing on the swivel, which contacts the switch. This may work with the E series like it does with the Elzettas.
What's your reasoning behind the desire to use AAs? Even on an AR with an Aimpoint using an AA cell, I'm now willing to go with AA cells, since all my other weapon lights use CR123s.
