more_vampires
- Joined
- Nov 20, 2014
- Messages
- 3,475
Anyone know the diameter of the AA tube? I've not been able to find the measure online. I've been looking to try to make a AA light to fit into an Elzetta FSB mount for an AR15. Says it needs a min of a .7 inch body. I've actually been able to fit a AA mini maglite, though that's not really a weapons light durable light. Also I should be able to take the head from a 123 SHO MDC and throw a 2AA body and the voltage should be enough right? If I decided to put 2 14500s in it wouldn't damage the light either right?
Not Malkoff, but Surefire M600AA is single mode, has rail accessories, is quick detachable, and you can go pressure switch or tail cap.Whole idea I'm throwing around is a tac light that I can detach and use and also uses a type of battery that you can find anywhere. There's almost no AA single output tactical lights really. The idea of using the E2 body is good since it has a proud button. Also I use a single point sling and have the front sling swivel removed.
I agree, AA weapon lights are super rare. Maybe old Gene can throw a turbo head on it so you can squash those alkies flat in no time.
