Can anyone explain the charge lighting on this unit? I had mine charging all day at work (8 hours maybe), which should have at least half charged it. It started with the first light pulsing, then the first light stayed on and the second light pulsed - I assume this was it indicating charging up.
But on the ride home it only lasted 20 minutes before switching to low power mode.
Now when I try to charge it, it quickly goes into blinking all three lights on about a 3 second interval. Does this indicate a problem? I might try it with some different batteries.
PS none of this is with the supplied charger as I don't have an adaptor. but it does the same with several other USB chargers.
