huffman.matthew
- Joined
- Oct 23, 2015
- Messages
- 35
Better news?OK so XHP35 HI gets a bit more throw but noticeably less lumen. Not the way to go. However I got better news. ;-)
Once more - XHP50???
If its XML2 size may be I can try to squeeze or rigg soemthing. But XHP50 is too big
I agree with this evaluation about the stock SC600 Mklll with standard XHP35. The head size limits the SC600 for being a good Throw Flashlight. :thumbsup:OK so XHP35 HI gets a bit more throw but noticeably less lumen. Not the way to go. However I got better news. ;-)
But XP-L and XM-L2 wouldn't work with the 12v driver, right? Unless maybe a triple or quad XP-L HI?
Wow, I just read through this entire thread from the beginning, my excitement building all the way through to the end . . . Thanks for trying Vinh!
The MK III is a pretty impressive light, but it's definitely not an order of magnitude greater than the MK 2. I really wonder why they bothered going the xhp 35 route. All it netted was a hundred lumen and .2 hour longer runtime. The build quality is quite an improvement tho, with the gold plated spring loaded buttons for contacts being totally premium. I just wish that there was some way to bypass the 1100 lumen limit imposed by the driver, and run the LED at it's rated 1800 lumen. Would have to disable the PID controller to run for any length of time... just some rambling thoughts. Need to pick the brains of a electrical guru to figure out how to up the amperage. Of course then you'd be running into heat issues, but the 1800 lumen would rock pretty hard.
Im not sure you'll even be able to tell the difference in the 1-200 lumen gain with the mkiii vs the mkii but I'm sure you can notice the greater throw with the xml2 on the mkii. So wouldn't this make the mkii better?
Nothing I put in makes any worthy upgrade. Sorry guys...
But at least a better tint I guess, for us that are picky! If you continue on this path and offer mods, of course
