Flashdark said:
rgp4544,
Richard, what specific set of work requirements were you trying to satisfy, and did the light perform adaquately?? Mine was tactical/utility backup, so my review in Post #40 was probably slanted in that direction. We need to hear from more people like yourself. What was your need and how did the K2 work out for you??!! ("Inquiring minds want to know")
Flashdark sends.
Flashdark,
The standard Kroma appears to have been designed specifically for pilots and mechanics and since I could think of no use for the IR beam on the Mil Spec I switched my order to the regular red-blue-white one.
Right now I've only had a Kroma for a little over a day and am still playing with it to get used to the switching mechanisms - the switch is a bit more sensitive than an A2. I haven't really used blue light before but the Kroma really is the first really practical light I've seen that has both red and white low output and I've looked for 20 years for such a light. For the past two or three years I've carried two lights - one red A2 and one white A2 - and before then there really wasn't a single decent light on the market.
My needs if broken down are basically:
1) preserving night vision for which the low level dual output red is ideal
2) occasionally needing a very low output white light
3) preflighting an aircraft which requires some good white light, preferably dual output white light.
#1 generally requires an extremely dim low level red light similar to the Kroma's low output red because if dark adapted more light tends to erase details and you can't see a chart or a paper well if a light is too bright. Even the red output from an A2 Aviator is enough to cause a lot of glare to bounce back from a piece of paper. The Kroma's low output red is actually better than the A2's red.
Thus far the Kroma appears to be an ideal working light, although it is a bit large, and I think most pilots and mechanics would love it.
After I get used to operating it with one hand and after the tailcap twisty smooths out with practice I'll fly with it and can report on results then, because right now it seems too easy to flash a white beam.
I'm still not sure exactly how I'm going to carry this thing though...it needs an adjustable neck lanyard...
Richard
