RI Chevy
Any of the M61 variants can be powered by 2-AA's. The voltage is so low that is starts off in DD and stays there. Very slow draw that goes with the very low voltage.
i don't mind at all! I'll try and take a good beamshot tonight. it's a phenomenal drop-in IMO. lights up everything around you pretty much
I tried. It lighted up but very dim. Battery measured 1.26voltsX2.
4000K XP-G2 Wildcats coming very soon according to an email from them i just got
Wallet....I may need you.
Grizz
At least you didn't recommend 'Get Both!'.
Well, decision time. Neutral Wildcat 4000k or...... Torchlab Neutral 4750k triple drop-in.
My M61WLL is pushing at least the same number of lumens (70) with the two AA's as it would normally output regulated on an 18650.
I'll do a light meter lux test between the lith and alkaline after these AA's (yep still going) run its course.
Can you estimate how many lumens you are seeing?
It looks more like 10lumens to me. Surely no where near what you observed of 70lumens.
This pic shows what I see with two fresh AA alkalines. The diffuser is about 2 stops over exposed. It's not a bright white like this. Everything else is nearly right on.
It's always good to be able to see what you're looking at, though. More throw into a patch of mottled brown/gray isn't all that helpful, and more lux won't do much better. Having more light in the wavelengths of colors you are looking at helps a ton.Cool does everything better, except possibly color rendering. More lumens and lux, so more light and more throw. Maybe it's only a little in this case, but it's there.
All current neutral Cree XP-G and XP-G2 LEDs have higher typical CRI than cool white, and you could order specific tint bins to increase that further. XM-L2 also seem to be that way, but not XM-L.And if the neutral emitter is not a hi-cri, or doesn't have a higher cri rating than the cool one, then it won't even do colors better.
I'd like to see a beamshot to compair the tint to my older M91AW if you don't mind.
