greenLED
nightrider, how are you sealing the front of the light against the elements? Is it just the optic sitting flush against the square aluminum or are you using an acrylic window in front of the optics?
KWillets said:The ledil's aren't clear as to whether they fit with wires on top of the emitter, or what installation is recommended. The design seems to allow wires to come from below and reach the solder pads, but the optic itself fits down around the metal ring and may contact the wire.
The glue pads are foam, and they may squish down over wires soldered onto the star without too much trouble. I haven't installed mine permantently, but test fitting seems OK.
Carbon fiber is a very good heat conductor, BTW.
greenLED said:nightrider, how are you sealing the front of the light against the elements? Is it just the optic sitting flush against the square aluminum or are you using an acrylic window in front of the optics?
Thanks Tim. Yes, the Crees were supposed to be from the same bin (at least in terms of brightness P3 bin). As far as tint I did not specify when I ordered... but I assumed that all would be the same. So as you can see there is also a "Cree lottery."Timson said:Love the refinements you've made to the design of your housing..Very professional looking. :rock:
Noticed your shot showing the different tints from the emitters.
Were they all supposed to be the same bin with regards to tint.
Any plans to do a Quad light to compete directly with the HID boys? :naughty:
I can feel a Quad 'Q2' with McR19's calling
Tim.
snowman said:Nice light and awesome documentation!!! Because single-track has different requirements than fire road or pavement riding I wonder if there is a way to seal it up but leave the ability to swap lenses before a ride. Maybe this could be the variable focus light of my dreams… as long as it can be well sealed.
I wonder how elliptical lenses would work in a biking application. If you mount it down low I think it could give good results.
Tidra said:could you compare your light with one from this fotos,...
http://tabla.mtb.si/gallery/album447
nightrider said:Tidra. It's hard to compare by looking at pictures. But, it's definitely brighter and whiter than the CateEye TripleShot. Probably not quite as bright as the HIDs... but close... I'm going to try and borrow a friend's L&M HID bike light to make some comparison shots in the next week or two.
Sawtooth said:It would also be cool to see comparison with your TriLux..:naughty:
Sawtooth said:Awesome! Cant wait to build my quad cree. (Of course we are snowed in now so I guess there is no hurry...)
How hot does the light get? Have you tried it at 1A? Does that shorten the life of the LEDs?
