Ven, you seem to be the authority on this stuff. Geez, how much have you got invested in all that gear?? I want to follow your lead, since you've done your research, and I really like that Kanger KBOX. I want to do this to quit smoking cigarettes, and I hear some of the cheaper stuff sucks and won't satisfy cigarette cravings at all. I'm hoping to just buy ONE good one. (Do they make these things in titanium?)
Seems like I have a LOT to learn!
Would not go that far :laughing: maybe i just get nothing right the 1st time and takes me ages :laughing:
Kbox is a cheap,up to now reliable unit but not in same league as say a vaporshark rDNA40............ Its kind of (for me anyway) a beater type of mod,for work,nipping out,it it falls and breaks............no deal. In uk it cost £23 delivered with voucher,the rDNA was £150...........big difference if one gets dropped.
Titanium nope,however there are ti mods,ones seen have been £500+ in UK so $750 ish:huh: forget that :laughing:
Not smoked since Jan 2013,this "vape" is what stopped me for sure,not the poor electric ones that glow and take cartridges etc.
Kbox is certainly not a bad start,it is designed more for sub ohm use(for their specific tank). Works well though with any tank,no need for sub ohm tank use and may find a little harsh at 1st or some getting used to. However there are + to it,can lower nic levels to get same "hit" also better flavour from sub ohm............rest is as far as you want to go,it can certainly get addictive in its own way,mods,tanks,coils etc etc .
For a nice vape,not too harsh and smooth, i like the delta 2 tank with any mod,other tank i use the most is the aspire atlantis with 5ml tank upgrade. However the v2 is out,soon the atlantis mega with more variable air control.
My advice if any local would be go in a vape shop and try out some mods or tanks along with flavours. I went deliberately away from tobacco flavours so no reminders of cigs...........what ever works for you basically .
If out of the mods right now i had to say my fav,then the vaporshark,however may be expensive on a mod if it is potentially not going to work for you,so Kbox would make better sense to start off with. Its basic,it works...........nice feel in hand,eats 18650 IMR/INR cells and has a floating pin(little pin inside that connects to tank is spring loaded,this makes sure it contacts the tank base). Then if happy and works,you will probably find you will end up getting more mods/tanks etc to rotate and as back up......hopefully no looking back
Edit- Of course the fluid plays an important part,right nic content,if heavy smoker dont start low!!! Look at making your own,its really easy and can custom the vape to your wants/needs. If later down the road,just make sure you buy decent branded juice. Not sure your way what is great,sure some excellent ones available. I like the pre-made patriot range by TW,they now have an new odyssey range with VG base(smoother).
May try it just for sake of,however i prefer now my own fluid...........by a long long way
