CelticCross74
this light is just TO bright. Many will die for want of darkness..
A huge lumen # that steps down in a couple minutes, has zero practical value. Usually you end up with a light that can really only maintain medium mode or lower for any useful time period. Unfortunately the flashlight market is like the digital camera market was 10 years ago, when all consumers looked at was the number of megapixels without understanding that more wasn't always better. Light regulation, while a great addition to flashlights is now being used to simply manipulate marketing specs. The other day I saw a series of new lights, from a well known manufacturer where the high mode runtime was listed as 90% of the medium runtime, but medium was 1/5 of the brightness of high.
As a result we now get expensive, huge lights that have a 3000+ lumen Turbo but only for a couple minutes, then step down to 1000 lumens(high) for the rest of it, and medium mode is 300 lumens or less, so you end up with huge gaps in brightness levels with actual usefulness. I would much rather see 1500 lumens for 30 minute runtime on turbo then a 1000-750 high and 300 lumen medium, 50 lumen low etc.
Thankfully some arenas have not accepted this trend of misleading marketing by gaming the ANSI spec system. I can only imagine how annoyed cyclists, caving, scuba people would be if their bike lights only stayed near the lumen rating for a few minutes before dropping to 30% of that level for the rest of the stated runtime. Seems like what ANSI really needs to do is change the spec for runtime to be 90% of original brightness, not 10% when calculating light runtimes.
Perhaps 90% is a bit aggressive, but I agree that 10% of original output isn't a useful metric at all. To account for battery regulation and heat dispersion under different circumstances 75% or 50% would still be a lot more useful than 10%. It would a allow manufacturers a little leeway while still preventing a lot of the cheating that's happening now.
I love the side by side idea for two cells, not so sure about four though.
You sound a bit more thorough and motivated than I am . I just wanted a general idea about size/shape.Nice and flat. Perfect to clip to your hat for a headlamp. You just need a brick on the back to balance it out.
Before I finished reading your comment Mark, I was going to tell you to hit the sides with a router. While you're at it paint it gray. And then put a recess in it for the switch, but where does it go?
Mark, I'm guessing that the batteries will be inserted into the longest side. So for comparing to your SC600 and SC63, you should rotate your model 90 degrees. I think?? Of course I'm just making this up.
Right: if the emitters were in line with the long-axis of the battery, i.e. on the long dimension of the box, then the reflectors would have to be so shallow that it would be a mule. No spot + spill beam at all. So in that case, it looks like the emitters are on the shorter dimension of the box.
Unless they are on the long side, but staggered in between cells? 4 cells, 3 emitters--is there enough room between the cells for a reflector of some depth?
