iamlucky13
- Joined
- Oct 11, 2016
- Messages
- 1,139
Of course, how could I forget? I knew there was something I was supposed to do...
SC53w to the left, SC5c II to the right. Both lights on max output. ISO 200, white balance set to "Daylight"
Thanks! I appreciate seeing the neutral white and high-CRI comparison.
Forgive my asking, but is it possible you mixed up the daylight and fluorescent balanced images? The images labeled as fluorescent are more like what I anticipated seeing for daylight balance, but that could just be my expectations being off-target.
It fits all my pockets Since I do not mind carrying something as big as a SC600 in my trouser pocket (I usually wear loose-fit clothes) I may not be the best person to ask about pocket fit.
Mainly I was curious if you think there is a significant different in how well the SC53 fits in the pocket compared to the SC5, or if the difference seems barely perceptible.
I have access to a pair of low budget calipers but using them is not my forte. I am not exactly sure what you mean by the narrower side of the head - I assume you you mean the side that sort of tapers, where the switch is located. I have tried to take some measurements, I hope you will find what you are looking for somewhere in the following bunch of pictures.
Link to full size image: https://s29.postimg.org/7aqschj8n/image.jpg
Excellent, Thanks! This one on the left is the measurement I was hoping you'd be able to do and you went even further. I wasn't sure which way Zebralight's spec was measured and how much narrower one side of the head was compared to the other.
Looks like (if I read the Vernier scale right):
SC53 Head - 25.15mm x 23.45mm (0.99" x 0.92")
SC5 Head - 26.30mm x 25.25mm (1.04" x 0.99")
SC53 Barrel - 18.1mm (0.71")
SC5 Barrel - 20.9mm (0.82")
