WalkIntoTheLight
Over the years I've purchased probably 14 Zebralights and over half of them were defective.
WTH??? If karma is a thing, then you must have won multiple lottery jackpots.
(3) My SC64w HI may have a hardware quality control issue: On several occasions I have turned it on in turbo only to have the light turn off again 1 second later. If I press the button again it will turn on and stay on. This problem seems to be intermittent, but has happened enough times to be worth mentioning.
My SC63w buzzes on turbo, but it works. That normal?
I've heard that on a couple of lights. Could be the whine from an induction coil. I don't think it's anything to be concerned about, except for the annoyance of it.
My SC64w HI experiences the "turn off from H1" only occasionally. My guess is maybe one out of every 10 or 20 turn-ons.Hey Fireclaw and others. I was hoping Zebralight had fixed the problems you are having. I ordered and posted videos of 4 defective Zebralights I received in a row earlier this year. All four would abruptly turn off when switched on to H1 (Max) and 3 of them experienced problems with the UI after programming the G6 and G7 groups. I was accused several times of not knowing what I was doing (which is not at all accurate) or defective batteries (nope,) or defective chargers (nope,) etc., but all four lights were absolutely defective. I have since bought the SC600 Plus and the SC600w Mk IV HI without any signs of the defects. I was able to return 3 out of the 4, but the one I'm stuck with they never could fix (after 3 attempts) - garbage. I ordered the new SC64w HI and am hoping I don't have to go through all that again. If it is defective, I will let you all know.
When the bug happens, I can override it and get it to stay on in high, by clicking to turn the light off, then click-and-hold to get to low, then turning it off and then on again. It will come on in H1 and stay on.
I'm undecided whether to return this one and buy a replacement SC64w HI. The problem is irritating when it happens, but it is intermittent and the workaround is quick. That said, for an $80 flashlight it would be nice if it worked properly all the time.
Apart from this defect, I like the light. I find the beam pattern much more useful than the pattern in my SC64w.
Yes, the DQG 18650 Tiny IV is considerably smaller than the SC64. That said, I think the SC64w HI is a much better light.Overall, I'll give it a 9/10. I don't think you'll find a smaller 18650 light. Maybe DQG has one?
