You know, it is *quite* ignorant for folks to be discounting the dangers of Lithium cells...in the extreme.
We see examples quite often, of them causing things to project, that could easily put out a child's eye, or get hot and disfigure/leave scares. That Lithium 123 cell M6 flashlight tailcap launched so hard, that it nearly went through a solid oak cabinet door!
The thread is found here, make sure to follow the thread to the end, you will see additional pictures later in the thread:
http://candlepowerforums.com/vb/showthread.php?t=78843
Here is another example of these Primary Lithium 123 cells (Battery Station) misbehaving, luckily this one didn't fail so badly:
http://candlepowerforums.com/vb/showthread.php?t=91245
And it is not always when you abuse the cells, occassionally they just blow up.
We are constantly getting new members, and it is important for them to understand the dangers and risks.
It is really stupid to the extreme, to think there are no dangers. We have seen multiple examples of 123 cells causing dangerous failures right here on cpf, and we are a very small cross-section of only ~20,000 users.
Once one is aware of the dangers of Lithium batteries, and how to treat them properly, not to mix brands, or *NOT* putting in a fresh 123 for one of the two that was dead- to save money, *NOT* running them down until the filament doesn't glow at all, *NOT* letting them bake in the sun in a flat black finish flashlight on a dashboard, *NOT* trying to recharge them, *NOT* trying to recharge them, *NOT* using cells that have a dent, and many other situations, then a person can make a
*WISE* informed choice, and also be aware of the dangers and how to treat Lithium cells accordingly.
I am very surprised that the majority flashlight manufacturers have not added circuitry to shut down a 123 cell flashlight when the cells drop below a given voltage. This would help eliminate one of the possible failure modes that can lead to venting, venting with flame, expulsion of internals, projectile launching of internals, or explosion. A safety venting mechanism in sealed flashlights might also be very useful in these situations, allowing a Lithium 123 cell flashlight to contain some of the failure modes, resulting in less danger/risk to the end user.
To give you just one example of the many safety bulletin/recalls dealing with 123 cells:
Name of product: Fuji Power and A&T Fuji Power
CR123A 3-volt lithium batteries originally provided with Galls® H.A.L.O. Tactical Flashlight.
Hazard: The batteries originally provided with the flashlight may overheat or explode presenting a potential for fire or personal injury.
Incidents/Injuries: Five reports of batteries overheating or exploding have been received, causing minor injuries such as burns and minor
property damage from fire.
http://list.uvm.edu/cgi-bin/wa?A2=ind0309d&L=safety&D=1&P=9889
And there are *PLENTY* of these type of safety/recall notices out there.
Just knowing that 123 Primary Lithium cells are in fact a risk, and understanding how to treat them properly to minimize that risk is very important.
