Speaking of batteries and since my last few Beam shots are from my Manker U21vn, I wanted to do another max run time test to see where the batteries are in this regard.
Basically after 1 year use and 102 cycles compared to BRAND New on October 24,2016.
I ONLY use these batteries for 15 to 20 minutes then put a fresh one in. ,,,Because I love MAX output on the trail!
In my house[EDC'S] I like ML and Low!
This applies to BOTH tests:
Starting VOLTAGES: 4.20V
5 minute rest b/w increments
Battery: Vappower IMR 26650 4200mAh
October 24, 2016 TEST:
15m=3.94v
25m=3.83v
35m=3.71v
October 15, 2017 TEST
15M=3.935V
25M=3.83V
35M=3.70V
Basically identical. No capacity loss in terms of run time.GREAT batteries after 1 year of use.
When I tested these in my Opus last October I got 4307mAh and HKJ got 4316mAh. BOTH tested @ 1 Amp
My Opus is usually about 1% higher than HKJ. Sometimes up to 3 % higher.In comparison to HKJ'S numbers the original Capacity test is ONLY
0.0021% OFF!!!
Based on this run time test I would suspect If I did another capacity test it would be very close to that.
