twistedraven
- Joined
- Oct 22, 2014
- Messages
- 1,810
No, it makes everything else look green, while I don't perceive it to be pinkish at all.
This is not good news as i have the Nichia version on the way also. Hope mine isn't trashed like your samples.
I have one nichia champagne bought from before the group buy and one black nicha from the group buy on the way as well. Now I'm praying for them to be in one piece.
Do you have an estimate ballpark lumen on your rot66 nichia @ 30 seconds ?
If you have Nichia LEDs with almost perfect tint why not just use that on moon as aux? how much less power does the aux LEDs use in comparison I wonder? and if so other than looking cool wouldn't aux LEDs be better in red for a night light? - anyway when the light is off the 4x blue aux LEDs in the button gives off way enough light to find it and navigate around the house in my experience.
Sooo been using this light the last several days. The thin body make the light relatively light but it also kinda make the lights feel cheap. The light is very well designed with excellent performance but does feel a bit cheap. Not sure if Its just me. But in general I think its a good light especially for the money.
Vinh, don't forget that this light uses 7075 Alu that has nearly 2x the strength and slightly better heat dissipation properties than the normal 6061 Alu in most lights.
Lighter the better for jacket pocket carry imo. That MT18/MF02 must be quite the brick.
ROT66 is 8oz with carrier
S6330 is 8.7oz
MK34 is 9.5oz
SR mini is 10oz
MM15 is 11.6oz
M43 is 12.5oz
MT18 is 18.8oz
If anything it is hefty only compared to the D4S at 4.4oz. I always wished that they would add more mass to the Emisar series. As is they are too light with just enough mass to hold things together.
Uhm, I feel very differently about Emisars. Thick shelves, thick walls, thick fins...
Without battery, D4 with 18350 tube is about 13g heavier than 18650 DQG Tiny 4th.
I've been told by Fireflies that if I can't solder a new LED in myself that I've to send my broken ROT66 XP-L to Vinh for repair.
