cnjl3
If you are not able to rebuild your JS pack then just get yourself some MN15's and use with the stock M6 battery holder. It really shines! Yeah, it's not the MN21 but it sure beats a dead M6.
Sorry to double post it up, but this is news. Surefire IS warranty covering the MN-15 in the M6 as of last week. I got an RMA and am getting a free replacement MN-15 for the M6.. In fact, the rep said that they know most people are having pretty good luck with the MN-15 in the M6. A new lamp assembly for me, only cost is sending the old, burned out MN-15 back to them.
This is a case where honesty paid off and Surefire customer service is great.
Thanks for the update, js.[...] Anyway, just thought I'd post here for all the reasons mentioned, but mostly to say that I still love this setup and still use it.
Surefire MN15 turbohead bulb. It was used for maybe 10 minutes total (at most) and I have the original packaging and so on for it. This is intended to be used in M3T setups, but you can use it in an M4 with two 17670 cells, or an M3T powered by two 17500s AFAIK (non-IMR?). - $20
Just a FYI, the MN15 is a phenomenally useful bulb for the SF M6, and perhaps one of the most efficient incan configurations ever made due to operating on two stacks of 3xCR123's in parallel:
The SF M6 X-LOLA: 200 lumens for 2.5 hours
holy cow! Kestrel you are the man as usual! I'll have to keep this MN15 now haha! thank you so much, I honesty didn't know about that config and it never occurred to me (it should've been something I realized on my own before given the M6's battery carrier versus how an M3 is set up)
thanks man!
edit: MN15 withdrawn till further notice
I'm just a little confused about all that you wrote in the 1st post, but at the very bottom state: "However, do not run the MN16 in the M6. The MN16 is NOT underdriven on a single stack of three 123's, so two parallel stacks will push it too hard, and it might possibly flash at start-up, or have a much foreshortened life."
Can you explain? I'm sure I'm misunderstanding something is all..
Also is this powered by the stock battery holder with 6x CR123's?
Thanks for any info!!
I am an LED junkie, but I have started playing with low-output incandescent lights here and there. I didn't have the budget for an M6, but you make it sound awfully nice.
JS, I've been reading some of your phenomenal threads from the start of the LED age. Wow, what a ride. Thank you for sharing what you find!
Great thread , I use a LF M3T-HO bulb in my M6 for some years now and it works perfect , nice round spot and a white beam.
I think it's almost the same as with a MN15.
GJR:wave:
HO-M3T High Output 9V, 380 Lumens High Output Lamp Assembly
(For 3 x CR123A or 2 x 3.7V Rechargeable Battery, M Series Flashlights)
-High Output Ultra High Pressure Xenon Lamp (380 Lumens)
-Highest Achievable Colour Temperature (3325K)
-Unique Filament Design
-Precision Machined Aluminum Lamp Assembly
-Every Lamp Assembly is Pre-Focused for the Ultimate Spot
-Compatible with all Flashlights that use the M Series Xenon Lamp Assemblies.
Compatible with:
SurefireR
M3 using 3 x CR123A
M3 using 2 x 3.7V Rechargeable
Runtime (CR123A): ~40 min
When I fire up my M6 with the MN15, I use one of mdcod's 2x18650 battery packs. Using bounce with a light meter and comparing it to other incan lights I own, I know that it at least reaches 200 beautiful lumens. Thanks js for revitalizing this thread. :thumbsup:
Bill
That is exactly what he is saying!! I keep mine loaded just like that with primaries for backup when heading out to the creek/river/lake.Bill your saying i can also run this bulb with this mdcod's 2x18650 battery packs. Dang i may need to get a backup MN15
I stumbled on this thread the other day so i went out and bought an MN15 received it today now i am waiting for darkness. So Bill your saying i can also run this bulb with this mdcod's 2x18650 battery packs. Dang i may need to get a backup MN15
