I gather they're just starting to cut their teeth on this kind of driver, with the person who designed the BLF GT driver being a member, and I presume sharing some of what he knows.
It will be a challenge to create an entire package as small as what Zebralight has achieved, however. By the specs, the SC64 is a hair slimmer (except for the bump around the button) and no longer than the FW3A's listed dimensions despite fitting in both a boost-buck driver and a reflector (the TIR optics in the FW3A are low profile in comparison).
I guess the main thing drawing me toward the FW3A is the Anduril firmware. Were it not for that, I think I'd lean more towards an SC64, because ultra high lumen outputs aren't a priority for me.
Fortunately, the FW3A reduces that gap a bit compared to some other drivers by using multiple linear regulators on two separate channels. That should give it good regulation up to somewhere in the 800-1000 lumen ballpark, down to 3.4V on the battery, or maybe a bit lower.
You should look into the drivers Texas Ace designed. They are triple channel. Single 7135 + 7x7135 + FET for low lows, 3 amp regulation and FET performance. Although it isn't a boost...
