Great data on the Malkoff MC-E's, MrG! This really helps me with a couple purchasing decisions. :thumbsup:
Very good lumen maintainence on the regulated version. Seems like it reaches a stable temp after 5 minutes, and not too much drop during that time to boot. Excellent! Indicates nice design work by Gene.
The performance of the IMR 18650 running the DD module was somewhat surprising to me. Compared to the data using the power supply, I'm assuming the batt was holding approx. 3.6V. I'd have expected an IMR of that size to hold a higher voltage under that load, thus delivering more current. However, I don't know if the DD Malkoff is resistored internally. If it is, that would clear up my confusion.
Gene, if you're reading this, can you tell us if the MC-E DD uses a current limiting resistor?
Hey MrGman,
Was just wondering if you still have access to an M30, could you test it running on a single primary or 2AA batts?
If not....cheers anyway!
Its not resistored internally and the battery was delivering around 12 watts of power, how much more do you want. From my testing so far we believe the phosphor got overheated from running this much power and degraded so that it will never reach the high brightness it might have initially in the first few minutes of running again. By the time I got it bigchelis had already put some serious run time on it.
Here are your special ordered test results just for you. don't share this with anyone else okay? :thumbsup:
M30 on a regulated power supply at various voltages and the current draw there of.
1.5V 0.84A 1.26W
2.0V 0.88A 1.76W
3.0V 0.97A 2.91W
3.2V 1.00A 3.20W
3.6V 1.10A 3.96W
4.0V 1.29A 5.16W
4.2V 1.42A 5.96W
4.5V 1.60A 7.20W
5.0V 1.89A 9.45W
And the brightness kept going up with these numbers. I could run the voltage up and down and watch the brightness constantly change. If you can run it with 3 Alkaline C or D cells at 4.5V that's going to be far brighter than 235 lumens out the front off of 1X18650 (for a while). Whether or not it will keep it as it gets hot is another test question.
I like it. :twothumbs
Partially due to my hotwire bent, I was as curious about Vbatt under load as anything else, and was expecting to see it higher if (and this is a big if) one could correlate the lumen data while using the power supply to the test using the IMR.
If they do correlate, then one could reasonably ask, for example, since the IMR pumped out 480 lumens from the DD module at turn on, was it delivering approx. the same voltage and current as the power supply did at 3.60V_3.01A, which pumped out 470 lumens at turn on?
However, these are questions for another topic (battery related), and bear no relation to what I think of Gene's excellent stuff.
Any issues with that size UCL glass in the Solarforce L2s?I just received the 26.8mm UCL glass from FLL to test with the Solarforce Bezels. They fit right in and are not too small such that the L shaped O-ring isn't pressing them.
I have a couple of the Solarforce L2s and would like to put better glass in them. Was unsure which UCL to get from FLL, but your post helped answer that question
1.5V 0.84A 1.26W
2.0V 0.88A 1.76W
3.0V 0.97A 2.91W
3.2V 1.00A 3.20W
3.6V 1.10A 3.96W
4.0V 1.29A 5.16W
4.2V 1.42A 5.96W
4.5V 1.60A 7.20W
5.0V 1.89A 9.45W
