Re: Law Enforcement Light
I participated in js' recent Tigerlight pass-around and liked the lights output, but the size was wrong for me; it DID fit in a C or D size belt-loop ring. For a large incandescent light that recharges on a charging hook, I would recommend it over the Magcharger or Ultrastinger.
I usually carry these on my duty belt:
- Pila GL3: old style, similar to the Wolf-Eyes, with the white/blue LED tail-cap. I added the 200 lumen lamp assembly, and use either 3 RCR123A 3.0 volt protected regulated li-ion cells or 2 x 18500 3.7 v protected li-ion cells;
- LED Logic Striker VG: I use the RCR123A cells sold by LED Logic
The GL3 is being tested by another LEO/PO elsewhere in Canada, who will be sending it back to me soon. I also loan out the VG to other LEO/PO for evaluation. I really like both, but I would even recommend going with the 12 v versions of the Pila or Wolf-Eyes for incandescent. If you want a dimmable, strobeable, high-powered LED, and can afford it, you could go with the Gladius, which I have tested, and liked - I have one, but do not use it, as it is awaiting further deployment.
I have a tool box that I carry in the trunk of my patrol car with my back-ups:
- 1 no-name, rechargeable, 1 million CP searchlight;
- 1 MXDL 3 AAA 3 watt LED: switch is wonky;
- 3 Dorcy 2 D 9" LED traffic wands: for traffic control;
- 1 Mag 2 C: modified with a borofloat lens, heavy stipple finished cammless aluminum reflector, either a KRP118, KPR120, KPR144 or other high-powered bulb, and either 3 RCR123A 3.6 v or 2 x 18500 cells;
- 1 Mag 3 C: with DB-3w LED module;
- 1 Mag 3 C: with DB-K2 LED module.
I have over 30 years of uniformed general duty policing experience, have worked in rural areas, towns of less than 1000 population, cities of less than 20,000 population and popular summer tourist points, and have mostly worked nights. I have always wanted better hand-held lighting tools, but only ever knew Maglite, Streamlight and Pelican products until I found CPF.
When I WAS using a big light (Mag 3 D, Kel-Lite 4 D, cheapy plastic Radio Shack 5 D) or using the light issued to my patrol car (Polystinger) I would shove it under my butt so I could grab it as I bailed out to contact "clients".
deputyman, if you want a Tigerlight, look at this thread:
https://www.candlepowerforums.com/posts/1568271#post1568271
If you want to go with a Gladius, check out:
https://www.candlepowerforums.com/threads/131336
or
https://www.candlepowerforums.com/threads/113146
Keep checking out the Lights - Sell and Trade threads for deals.
