xevious
Thanks for telling us about MixGlo.com, gunga. I just received my first shipment from them and their service is absolutely superb.Ok. Some people have asked about trit installs on this light. I'll provide some info.
I get my trits and norland 61 at mixglo.com. You will need 10x of the 1.5x6mm trits. I use a Jaxman U1 UV light (365nm) but any good UV light will do. Sunlight also works well but it's a bit tricky for the trits at the end.
- The tritium is totally sealed in a metal foil plastic bag, which I think makes it very difficult to detect the extremely small amount of radioactivity from the tritium--thus, no worries on shipment rejections.
- The case that the tritium is stored inside is a rectangle of dense foam with a small rectangle excavated for the tritium. A little wadding of cotton goes over that to keep the tritium gently in place. And then a thin top layer of foam goes over that, which is then tucked into a snap closure plastic case. All of this is tucked into that foil/plastic bag.
- The Norland NOA61 comes in a tiny screw cap plastic bottle, the kind used for eye drops. That is sealed in a plastic bag and then tucked inside a sealed foil/plastic bag, which is then fitted inside a small segment of PVC. Incidentally, the 1cc of NOA61 looks so incredibly small, you'd think it's not enough... but it definitely is, probably good for seating a dozen trits.
It would be nice if they'd include a mini pipette. I used that before and it's really terrific for application of Norland. Unfortunately, due to the nature of Norland, it's usually only good for 2 applications at most. But I do agree that wooden toothpicks can work. I take a small Exacto-knife and shave the tip a bit to make it more "wedge" like. This helps for application and for scraping excess.
