This is a terrific resource, thanks so much MrGman.
Do you have a ROP you could test? I'll bet that a ROP really is brighter on 2xLithium-ion than on 6xNiMh as most of us have witnessed; I'd just like to know by how much.
+1
I'd really like to see some popular SureFire flashlights such as: the new L1, E2L, E2DL, E1B, KL5A. The new Inova T2, T3, T4. All popular Dereelights and more incandescent lights as well. That would be sweet!
Just wondering:
EagleTac T10C2: Cree XR-E Q5 inside
Draws 0,96 A on hight (2 fresh batteries = 6 V)
under load: 5,3 V
= 5,1 Watt from the batteries
Driver efficiency 90 %
= 4,6 Watt to the Led
Vf approx. 3,7 V (at 1.000 mA)
= 1.240 mA to the Led
Cree XR-E Q5 max. 114 lm at 350 mA
approx 250% at 1.240 mA
= 285 lm (emitter lm)
Relative Light Output approx. 85% at 100°C junction temperature
=242 lm (emitter lm)
minus some losses (reflector, lens) approx. 10%
--> 220 lm out of the front
(Article about efficiency: link)
ROP = "Roar Of the Pelican"
ROP is a maglite modification that uses one of the two #3854 "Big D" Pelican 6v bulbs being overdriven. The 3854-high bulb is approximately 700 real lumens and the 3854-low bulb is approximately 500 lumens (but obviously it depends on how much voltage you supply and the "sag" your cells experience). The standard ROP mod uses a 2D maglite, an aluminum reflector and glass window (as they are resistant to heat), and a 6AA->2D cell adapter in which you place 6 NiMH cells (usually LSD or high-current ones that can take the current draw). Some people (myself included) use two li-ion cells instead because they sag less, thus providing more light. The 3854-high can take about 8.5v before flashing and I believe the 3854-low bulb can take around 9v.
The reason I ask about the ROP is that is is a very common "first hotwire mod" among CPFers due to being both very bright and relatively inexpensive.
I think this will be the most useful thread on CPF, it will save a lot of people money from buying over rated lights. Thank You
+1 for sure. I do hope the mods take notice of this thread. The best flashlight buyer is an informed buyer.
Where are all the EagleTac doubters now????:thinking:
It takes time and money to do real science. You guys could probably come up with the money collectively, but I don't have the time to do all of these well. If it was just a quick reading in the IS and nothing more that might be possible. But I don't have hardly any interest in most of these lights and I don't want to have to keep paying return shipping and use my lunch hour to make trips to the post office to return lights. A few "key" lights of real interest and controversy would be sufficient.
What I will be interested is the new Lumens Factory D36 in the M90 Rattlesnake to see if its brigher and has better throw than D26 type pills.
I would want it with very light orange peel reflector and not a heavy OP texture pattern. But the weather has already started turning south and my choice of targets will blow away and get ruined in the rain. Beamshots of tree tops just don't do it for me (as you can probably tell).
We will figure something out later. G
Energie, your assumptions are off, your math is off.
Assume 270 lumens out after then initial warm up (15 seconds or more). For some one pulsing it on and off. 282 to 276 lumens is what I kept seeing.
Some impressive lights!!
Thanks MrGman!
Does anyone have the T10C2 and the T10L or P10C2 for comparison? Light-Reviews shows the T10C2 and T10L having similar output but EagleTac rates them differently, and the P10C2 as lower output even though EagleTac rates it the same as the T10C2.
Also, if the P10A2 with 2 AA's is running at 1.3a, shouldn't it be as bright as the T10C2?
I'm confused........but still learning!
Thanks everyone for what I've learned so far!
No, not at all. Alkalines should never perform like CR123. AAs under that high load will sag like a motherforker. They just can't provide the juicy needed to achieve that power. CR123s are very pwerful cells, so light fueled by them should never be compared to plain alkaline-powered lights.:thumbsup:Also, if the P10A2 with 2 AA's is running at 1.3a, shouldn't it be as bright as the T10C2?
